VLAN Management
Can we apply a shared Bandwidth for a Specific VLAN, i mean every client of a VLAN share this bandwidth.
Purple
Re: VLAN Management
You can certainly do so. The best place to do this would be on the router/switch that performs inter-vlan routing for this VLAN. Apply a QoS service-policy to this interface that shapes/polices the traffic to whatever you require.
Hope that helps - pls rate the post if it does.
Paresh
Re: VLAN Management
I am currently using L3 & L2 envirment, all VLAN creat on the L3 switch, L3 is working in a VTP Server mode and L2 ina client mode, right ?
now please tell me how can i creat this QOS on the L3(3550) switch, where i develop all the VLAN.
I would like to specify the shared bandwdith for the each VLAN in a L3 switches.
Thank You.
Purple
Re: VLAN Management
ACtually, I must correct something from my last post - you can't apply QoS service-policies to a VLAN interface on a 3550. Therefore, you can't really control total traffic for a VLAN on the 3550.
However you can limit the bandwidth per port using something like the following:
policy-map Policer
class class-default
police 2000000 625000
interface fas0/1
service-policy input Policer
service-policy output Policer
Paresh
Re: VLAN Management
Can i apply this policy on VLAN interface, and assigned a Ip address to that interface,
every client set the default gateway of this IP Address,
will it work correct ?
policy-map Policer
class class-default
interface vlan 100
202
