Vlan Running Config fetch failed
hlichiere
I have this msg when i try to archive the config file from all the device (1400 devices) :
VLAN RUNNING Config fetch failed....VLAN Config fetch is not supported usinf TFTP.
I'm reading some topics about. I don't known why it doesn't work.
I'am trying manualy to copy the vlan.dat from a device to LMS with TFTP. To do that, i have created an empty vlan.dat file on /tftpboot. It works fine.
This directory have a permission of 777 for root and other.
Attached the dcmaservice.log
It seems LMS can't create a new temporary file to /tftpboot. Rgards
LMS uses the routing table to find the appropriate local server address. However, this can be overridden on a per-device basis by editing the RME ID under RME > Devices > Device Management > RME Devices > Edit Device Attributes.
Joe Clarke
RME is trying to copy vlan.dat to:
tftp://192.168.1.147/20091028191759232-10.126.44.10.cfg
Is that the correct IP address of the RME server? Is that the same address you used in your testing?
Oups...I'm tied.
You are right. It's a secondary address. Where can i change it. Thx
