04-15-2009 03:42 AM
I see in some cisco switches that vlans in trunk port misses frequently.what must be the reason behind this??
04-15-2009 06:30 AM
Can you provide more information?
For example:
If you are referring to something like:
show run int fa 0/1 giving the following output:
interface fastethernet 0/1
switchport mode trunk
vs
switchport trunk allowed vlan 1,25,200
or are you referring to something like show vtp status or show spanning-tree output.
04-15-2009 06:30 AM
For example:
vs
04-15-2009 08:05 PM
Thanx for ur reply,
i have tried sh run int faX/y and also tried sh int fax/y switchport
After i manually add vlan,then it starts to work.Its happening to some switch trunk port only .
its cisco 2950 24 port switch.
