Webcast-Catalyst9k
VMS manage FWSM with multiple context
I have one FWSM with multiple context, the operation mode is transparent. I want to use Ciscoworks VMS to manage it. How to setup Ciscoworks VMS MC for firewall? ( setup firewall MC for admin context only, or need to setup firewall MC for each security context? )
Best Regards,
1 REPLY
Re: VMS manage FWSM with multiple context
be aware of: CSCsb89594, RME does not work for PIX with multi context feature enabled
Symptom: Multi Context feature for the PIX is only available in PIX version 7.0 or later. If this feature is enabled,
RME will not be able to add PIX into RME Inventory or to get PIX config archive anymore.
Conditions: This is only applicable to PIXes with multi context feature when running 7.0 or later images.FW module on the Cat6000 is not affected.
Workaround: None.
127
