Voice problem....
Hi.
We're having voice problem with the 2 sites.voice is sometimes umping and sometims totaly dead.We have replaced the
voice module already at site B, and reset the PBX at site A, but I think it hasn't been resolve.
Can please someone check the config if there's any hole in it??
here's the config.
****SITE A*****
version 12.4
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname *********
boot-start-marker
boot-end-marker
logging buffered 10000 debugging
enable secret
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate slot 2
ip cef
no ip domain lookup
ip host ***********
ip host ***********
voice-card 0
no dspfarm
voice-card 1
no dspfarm
voice-card 2
no dspfarm
voice rtp send-recv
class-map match-all Control
match ip precedence 6
class-map match-all Voice
match ip precedence 5
policy-map LLQ_12ch(320K)
class Control
bandwidth 16
class Voice
priority 320
class class-default
fair-queue
random-detect
policy-map GE_Precedence
class class-default
shape average 1000000 1000000 0
service-policy LLQ_12ch(320K)
interface GigabitEthernet0/0
description To_SiteA
bandwidth 1024
ip address 10.0.100.1 255.255.255.252
duplex full
speed 100
media-type rj45
no cdp enable
service-policy output GE_Precedence
interface GigabitEthernet0/1
description To_-LAN
ip address 10.0.0.65 255.255.255.0
ip policy route-map PRECEDENCE
duplex full
speed 100
media-type rj45
no cdp enable
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
no cdp enable
ip local policy route-map PRECEDENCE
ip route 0.0.0.0 0.0.0.0 10.0.0.1 name To_NetS*****
ip route 10.0.3.0 255.255.255.0 10.0.100.2 name To__LAN
ip route 10.0.6.0 255.255.255.0 10.0.100.2 name To__LAN
ip route 10.0.110.0 255.255.255.252 10.0.100.2 name To_-WAN
ip route 10.0.120.0 255.255.255.252 10.0.100.2 name To__WAN
ip route 10.0.200.0 255.255.255.252 10.0.100.2 name To_Maintenance
no ip http server
no ip http secure-server
access-list 1 remark *** For_telnet_from_Maintenance&CE-R ***
access-list 1 permit 10.0.0.0 0.0.255.255
access-list 100 remark *** For_Control_Class ***
access-list 100 permit tcp 10.0.100.0 0.0.0.3 any eq telnet
access-list 100 permit tcp 10.0.100.0 0.0.0.3 eq telnet any
access-list 100 permit icmp any any
access-list 110 remark *** For_Routine_Class ***
access-list 110 permit ip any any
no cdp run
route-map PRECEDENCE permit 10
description For_Control_Class
match ip address 100
set ip precedence internet
route-map PRECEDENCE permit 20
description For_Routine_Class
match ip address 110
set ip precedence routine
control-plane
Re: Voice problem....
voice-port 0/1/0
operation 4-wire
type 5
cptone JP
timeouts initial 5
timeouts interdigit 2
description **** E&M ch1 ****
voice-port 0/1/1
operation 4-wire
type 5
cptone ***
timeouts initial 5
description **** E&M ch2 ****
voice-port 0/2/0
operation 4-wire
type 5
cptone ***
timeouts initial 5
description **** E&M ch3 ****
voice-port 0/2/1
operation 4-wire
type 5
cptone ***
timeouts initial 5
description **** E&M ch4 ****
voice-port 1/0/0
operation 4-wire
type 5
cptone ***
timeouts initial 5
description **** E&M ch5 ****
voice-port 1/0/1
operation 4-wire
type 5
cptone ***
timeouts initial 5
description **** E&M ch6 ****
voice-port 1/1/0
operation 4-wire
type 5
cptone ***
timeouts initial 5
description **** E&M ch7 ****
voice-port 1/1/1
operation 4-wire
type 5
cptone ***
timeouts initial 5
description **** E&M ch8 ****
voice-port 2/0/0
operation 4-wire
type 5
cptone ***
timeouts initial 5
description **** E&M ch9 ****
voice-port 2/0/1
operation 4-wire
type 5
cptone ***
timeouts initial 5
description **** E&M ch10 ****
voice-port 2/1/0
operation 4-wire
type 5
cptone ***
timeouts initial 5
description **** E&M ch11 ****
voice-port 2/1/1
operation 4-wire
type 5
cptone ***
timeouts initial 5
description **** E&M ch12 ****
dial-peer voice 10 pots
destination-pattern 70T
port 0/1/0
dial-peer voice 20 pots
port 0/1/1
dial-peer voice 30 pots
port 0/2/0
dial-peer voice 40 pots
port 0/2/1
dial-peer voice 50 pots
port 1/0/0
dial-peer voice 60 pots
port 1/0/1
dial-peer voice 70 pots
port 1/1/0
dial-peer voice 80 pots
port 1/1/1
dial-peer voice 90 pots
port 2/0/0
dial-peer voice 100 pots
port 2/0/1
dial-peer voice 110 pots
port 2/1/0
dial-peer voice 120 pots
port 2/1/1
dial-peer voice 76 voip
description To_SiteB
destination-pattern 76T
session target ipv4:10.0.110.1
incoming called-number .T
playout-delay maximum 240
playout-delay nominal 110
playout-delay minimum high
codec g729r8 bytes 40
fax rate 9600 bytes 40
ip qos dscp cs5 media
ip qos dscp cs5 signaling
no vad
dial-peer voice 74 voip
description To_SiteB2
destination-pattern 74T
session target ipv4:10.0.120.2
no vad
line con 0
exec-timeout 5 0
password
logging synchronous
login
exec prompt timestamp
stopbits 1
line aux 0
exec-timeout 5 0
password
logging synchronous
login
modem InOut
transport input all
stopbits 1
flowcontrol hardware
line vty 0 4
access-class 1 in
exec-timeout 60 0
password
logging synchronous
login
scheduler allocate 20000 1000
ntp master 1
end
*******Site B***********
version 12.4
hostname *********
boot-start-marker
boot-end-marker
enable secret
no aaa new-model
ip cef
no ip domain lookup
ip host *******
ip host *******
voice-card 0
no dspfarm
voice rtp send-recv
policy-map LLQ_6ch+2ch(168K)
class Control
bandwidth 16
class Voice
priority 168
class class-default
fair-queue
random-detect
policy-map LLQ_2ch(48K)
class Control
bandwidth 16
class Voice
priority 48
class class-default
fair-queue
random-detect
description To_LAN
ip address 10.0.3.3 255.255.255.0
duplex full
speed 100
media-type rj45
no cdp enable
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no cdp enable
description To_WAN
bandwidth 1024
ip address 10.0.110.1 255.255.255.252
ip accounting output-packets
encapsulation ppp
no cdp enable
service-policy output LLQ_6ch+2ch(168K)
interface Serial1/0
bandwidth 128
no ip address
encapsulation frame-relay IETF
serial restart-delay 0
frame-relay traffic-shaping
frame-relay lmi-type q933a
interface Serial1/0.1 point-to-point
ip address 10.0.120.1 255.255.255.252
no cdp enable
frame-relay class VoIP(128K)
frame-relay interface-dlci 999
interface Serial1/1
no ip address
shutdown
no fair-queue
no cdp enable
interface Serial1/2
no ip address
shutdown
no fair-queue
no cdp enable
interface Serial1/3
no ip address
shutdown
no cdp enable
ip route 0.0.0.0 0.0.0.0 10.0.110.2 name To_Default
ip route 10.0.6.0 255.255.255.0 10.0.120.2 name To_LAN
no ip http server
map-class frame-relay VoIP(128K)
frame-relay cir 112000
frame-relay bc 1120
frame-relay be 0
frame-relay mincir 112000
frame-relay fragment 160
service-policy output LLQ_2ch(48K)
access-list 100 permit tcp 10.0.110.0 0.0.0.3 any eq telnet
access-list 100 permit tcp 10.0.110.0 0.0.0.3 eq telnet any
no cdp run
control-plane
voice-port 0/1/0
operation 4-wire
type 5
signal immediate
cptone ***
timeouts initial 5
voice-port 0/1/1
operation 4-wire
type 5
signal immediate
cptone ***
timeouts initial 5
voice-port 0/2/0
operation 4-wire
type 5
signal immediate
cptone ***
timeouts initial 5
voice-port 0/2/1
operation 4-wire
type 5
signal immediate
cptone ***
timeouts initial 5
voice-port 0/3/0
operation 4-wire
type 5
signal immediate
cptone ***
timeouts initial 5
voice-port 0/3/1
operation 4-wire
type 5
signal immediate
cptone ***
timeouts initial 5
port 0/1/0
port 0/1/1
port 0/2/0
port 0/2/1
port 0/3/0
port 0/3/1
forward-digits 0
dial-peer voice 70 voip
session target ipv4:10.0.100.1
no vad
no vad
line con 0
exec-timeout 0 0
password
logging synchronous
login
stopbits 1
line aux 0
exec-timeout 5 0
password
logging synchronous
login
modem InOut
transport input all
stopbits 1
line vty 0 4
access-class 1 in
exec-timeout 5 0
password
logging synchronous
login
ntp clock-period 17180002
ntp server 10.0.100.1
end
Thanks a LOT
117
