VPCON3000 in CiscoWorks 3.0
Can we add VPNCON 3000 in CW 3.0?? If yes, then how, and if not, then wat tool can be used for configuration audit/backup etc?
Also, can you please tell me the link for all the devices that can be integerated with CW 3.0 ?
1 REPLY
Re: VPCON3000 in CiscoWorks 3.0
Yes, LMS supports the VPN3000 series. RME uses HTTPS to fetch the configuration from these devices. The supported device tables are at:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.0/device_support/table/lms30sdt.html
98
