VPN monitor
Dear all
I need a software for monitoring my ipsec vpn tunnel.
the status of vpn monitors are very important
please guide me
Re: VPN monitor
Used to be VPNMS under Ciscoworks but it now is sold as Cisco Security Device Manager now.
VPN monitor
Check
http://www.vpnttg.com/
Advantage   of VPNTTG over other SNMP based monitoring software’s is  following:   Other (commonly used) software’s are working with static OID  numbers,   i.e. whenever tunnel disconnects and reconnects, it gets  assigned a  new  OID number. This means that the historical data, gathered  on the   connection, is lost each time. However, VPNTTG works with VPN  peer’s  IP  address and it stores for each VPN tunnel historical  monitoring  data  into the SQL server and into the RRD (Round Robin  Database) file.
392
