Does anyone know of or has anyone installed management software to allow easy deployment, creation, modification of VRF-Lite/Multi-VRF on multiple routers through an organisation
The OSPF Support for Multi-VRF on CE Routers feature provides the capability of suppressing provider edge (PE) checks that are needed to prevent loops when the PE is performing a mutual redistribution of packets between the OSPF and BGP protocols.Refer URL
