Community Member
WAAS OID
is there anyone monitoring WAAS? like the cpu.,memory or  interface.I would like to monitor using Cacti and if any one locate me all usefull OID for WAAS I am really apperciated.
1 ACCEPTED SOLUTION
Re: WAAS OID
The object is hrProcessorLoad:
hrProcessorLoad OBJECT-TYPE
    SYNTAX     Integer32 (0..100)
    MAX-ACCESS read-only
    STATUS     current
    DESCRIPTION
        "The average, over the last minute, of the percentage
        of time that this processor was not idle.
        Implementations may approximate this one minute
        smoothing period if necessary."
    ::= { hrProcessorEntry 2 }
Re: WAAS OID
Go to ftp://ftp-sj.cisco.com/pub/mibs/supportlists/wafs/WAFSMIBSupportList.htm to view the list of MIBs supported by the WAAS.  The HOST-RESOURCE-MIB will give you CPU and memory utilization information.  The device does support the ifTable, so the standard ifInOctets and ifOutOctets will provide you interface utilization stats.
Community Member
Re: WAAS OID
thank you very much for your response. I got solution for most of my objective excpet CPU. I could't find OID for CPU utilization on HOST-RESOURCE-MI.
Re: WAAS OID
    STATUS     current
    DESCRIPTION
Community Member
Re: WAAS OID
Thank you so very much!!!
547
