Community Member
WAE 7326 - interface standby vs active-active configuration
i am configuring two WAE 7326 in our network eenvironment as cache in proxy mode. it is to be connected to a switch just before the firewall.
while configuring i came accross two types of interface configurations active-standby and active-active. which one is prferable and what is the best practice for interface configuration and disk space allocation?
Thank You and Kind Regards,
ET.
1 REPLY
Silver
Re: WAE 7326 - interface standby vs active-active configuration
Active/Active Failover and Active/Standby Failover. Each failover configuration has its own method to determine and perform failover. With Active/Active Failover, both units can pass network traffic. This lets you configure load balancing on your network. Active/Active Failover is only available on units that run in multiple context mode. With Active/Standby Failover, only one unit passes traffic while the other unit waits in a standby state. Active/Standby Failover is available on units that run in either single or multiple context mode. Both failover configurations support stateful or stateless (regular) failover.
For further information click this link.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080834058.shtml
297
