WCS6.0.132.0 Startup Error after Installation
I installed WCS6.0.132.0 on a Win2k3 SP2 Engine for the first time. But as I started the WCS service I got an error.
It seems that the health monitor would not start.
As the WCS6.0.132.0 would not work I installed WCS5.2.148.0 and it works now.
In the install log I found a non fatal error:
Custom Action: com.cisco.packaging.SystemRequirementsCheck
Status: ERROR
Additional Notes: ERROR - class com.cisco.packaging.SystemRequirementsCheck.install() runtime
Until now I have not found any bug IDs for WCS6.0.132.0.
I use Win2k3 SP2 English with German language and keyboard settings.
Re: WCS6.0.132.0 Startup Error after Installation
faceing the same error.
Looks like it is an Java-error.
Check your
\webnms\logs\hm_launchout.txt
if you have Heap-Size errors,too.
Reinstalling from scratch right now.
regards, Dirk (Please rate if helpful)
Hi Dirk,
youre right it was a java error. I contacted our sales engineering team. I got following working solution.
I changed a section in file WCS6.0.132.0\bin\startServer.bat:
Old: set JAVA_OPTS=-server -Xms256m -Xmx%MAX_HEAP_SIZE% -XX:MaxPermSize=256m -Xrs -XX:+HeapDumpOnOutOfMemoryError -XX:HeapDumpPath=logs
New: set JAVA_OPTS=-server -Xms256m -Xmx1024m -XX:MaxPermSize=256m -Xrs -XX:+HeapDumpOnOutOfMemoryError -XX:HeapDumpPath=logs
Will try it in a minute.
Setup is restoring my DB right now ;-)
Is working.
I just modified the statement:
old: set MAX_HEAP_SIZE=m
new: set MAX_HEAP_SIZE=1024m
It's working now.
Enjoy your day!
The bug you faced is : CSCta18874
I have the same problem with the HealthMonitor Service, but on the linux version.
here the hm_launchout.log
more hm_launchout.txt
JAVA_HOME=./../jre
Starting Health Monitor as a primary
Checking for Port 8082 availability... OK
Starting Health Montior Web Server...
Health Monitor Web Server Started.
Starting Health Monitor Server...
Health Monitor Server Started.
Starting WCS Server
Invalid maximum heap size: -Xmxm
Could not create the Java virtual machine.
where i have to modify the java option under linux redhat ?
startServer.sh in /opt/WCSx.x/bin
export JAVA_OPTS="-server -Xms256m -Xmx1024m -XX:MaxPermSize=256m -Djava.awt.hea
dless=true"
Ok thanks it works. The bin folder was hidden with the default installation.
There is a defect for this : CSCta18874
410
