Webcast-Catalyst9k
Webmail from the inside
I thought I had everything straight on my new ASA but now I cannot get to webmail from the inside unless I use the private IP. Same with FTP.
Any suggestions?
Silver
Re: Webmail from the inside
Verify ACL in your ASA may be you misconfigured so its happening.
And you used to be able to use the public IP?
Check this link and post here if you have additional questions.
http://blogs.interfacett.com/mike-storm/2006/6/29/bidirectional-nat-on-a-cisco-pix-or-asa.html
HTH and please rate.
289
