Community Member
What does CRMDMGTD mean
I have been searching for what the "crmdmgtd" acronym means. Does anyone know?
I know how it is used to start and stop services on the CiscoWorks server. I have to believe that the developer of this command syntax had an original meaning behind crmdmgtd.
1 REPLY
Re: What does CRMDMGTD mean
CRM used to be the name of RME before CiscoWorks 2000 was released. It contained what is now the Common Services and RME components. The acronym stands for Cisco Resource Manager. Dmgtd is short for Daemon Management Daemon. Suffixing an application name with 'd' is a UNIX convention which denotes that this process is designed to run in the background.
229
