What is the correct way to patch the PI secondary appliance?
I have installed two appliances, the primary and the secondary and went to patch them both
before making the HA configuration.
The primary I could install the PI_1_3_0_20-Update.4-16.tar.gz patch without problem:
show version
Cisco Application Deployment Engine OS Release: 2.0
ADE-OS Build Version: 2.0.1.038
ADE-OS System Architecture: x86_64
Copyright (c) 2005-2010 by Cisco Systems, Inc.
All rights reserved.
Version information of installed applications
Cisco Prime Network Control System
Version : 1.3.0.20
Patch: Cisco Prime Network Control System Version: Update.4.16
On the secondary after the setup was made and reboot I see this status:
ncs status
Health Monitor Server is running.
Reporting Server is Stopped
Ftp Server is Stopped
Database server is stopped
Tftp Server is Stopped
Matlab Server is Stopped
NMS Server is stopped.
SAM Daemon is not running ...
DA Daemon is not running ...
Syslog Daemon is not running ...
If I try to start ncs on the secondary I get:
ncs start
Starting Network Control System...
Unable to verify hardware.
This may take a few minutes...
Health Monitor is already running.
Failure during Network Control System startup.  Check launchout.log for details.
start
The launchout.log is below:
Starting Health Monitor as a secondary
Checking for Port 8082 availability... OK
truststore used is /opt/CSCOlumos/conf/truststore
Starting Health Montior Web Server...
Health Monitor Web Server Started.
Starting Health Monitor Server...
Health Monitor Server Started.
On the sh logging system I see the gz file being unbundling is the last log about the ptach install.
On the primary the patch installed in 10 minutes.
Is there any special procedure to make this patch installed?
Thanks for any help
Everyone's tags (3)
290
