Hi Kenneth,
To format it, simply use:
format slot0:
Note that you can use only Type I or Type II Flash memory cards.
The largest sized PCMCIA you can buy from Cisco is 256 MB (MEM-12KRP-FD256M)...
Hope that helps... pls rate the post if it does.
Paresh
