01-22-2014 03:34 AM
I has a client they want upgrade WCS 7.x to PI2.0, i received three PAKs one is (L-PI2X-LF-100) PI 2.x - Lifecycle - 100 Device Lic, (L-W-PI2X-50-U) WCS to PI 2.x Upg 50 Device and (L-PILMS42-KIT) PI - LMS License Kit.
The first two PAKs was completed but got the problem on LMS license !! When i try to import LMS license into PI and got failed !! May i know what is the purpose of LMS License Kit ?
P.S.
Our client does not has LMS before and they want upgrade WCS to PI only.
Keith Chan
Solved! Go to Solution.
01-22-2014 05:30 AM
The LMS license wont get installed on the Cisco PI software. As Cisco PI still doesn't doesnt have all the LMS features imported, LMS license is provided for those who want to install Cisco Prime Lan Management Software (LMS) separately.
You can use that license individually there.
For more details on LMS check :
http://www.cisco.com/en/US/products/ps11200/
You can download LMS 4.2 and install license, if you wish to use separate application to manage wired infrastructure, from here:
http://software.cisco.com/download/type.html?mdfid=284259296&flowid=37207&softwareid=280775102
* Proceed as per the platform.
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
01-22-2014 05:30 AM
-Thanks
Vinod
