Community Member
When change cisco device
our company have:
3640, 2610, 2950 had been used lot of years,
how long they can run, and when we need update its.
Re: When change cisco device
They can run until they fail :)
However, you should check the EOS of the products. Some people, replaced them because they don't have enough resources (DRAM and FLASH) to install new IOS.
EOS for 3640
http://www.cisco.com/en/US/products/hw/routers/ps274/prod_eol_notice09186a008032d840.html
EOS for 2610
http://www.cisco.com/en/US/products/hw/routers/ps259/prod_eol_notice09186a008032d4c2.html
EOS for 2950
Let me know what is the exact model of your 2950
Community Member
2950 model is:WS-C2950-24
But we had a single point of failer at 3640, because of only one DDN connection. We must prevent this event, so what can i do?
If uptime is important to you, you have to consider implementing redundancy both in the device and uplink. Even you have back-to-back hardware maintenance, when the device fail it will take hours to recover it.
WS-C2950-24 is not EOS yet.
112
