10-22-2013 02:19 AM
Hi All,
Question......
Does anybody know where CNA stores the Topology layout?
Reason for my asking is that I'd like to transfer the local settings I have to a central monitor.
It will save me a huge amount off work if I could just copy/paste a folder with the local content to the new machine.
Basicaly this works except for the topology layout so my guess is that this stored in a different place (?)
Thanks in advance,
Best regards,
Solved! Go to Solution.
10-22-2013 06:52 AM
Cisco Network Assistant saves topology changes in XML format in your work space. use system START -> Rick click mouse Menu -> EXPLORE. This should open a window in C:\Docs and Settings\. Please make sure you have permissions to read/write the .networkassistant folder by right mouse clicking and opening properties, security TAB. In the "communities" folder should be a XML file named after your CNA community name.
Thanks-
Afroz
[Do rate the useful]
10-22-2013 06:52 AM
Thanks-
Afroz
