Where does CNA Stores it's topology?
quintiqhq
Hi All,
Question......
Does anybody know where CNA stores the Topology layout?
Reason for my  asking is that I'd like to transfer the local settings I have to a central monitor.
It will save me a huge amount off work if I could just copy/paste a folder with the local content to the new machine.
Basicaly this works except for the topology layout so my guess is that this stored in a different place (?)
Thanks in advance,
Best regards,
B@rt
AFROJ AHMAD
Cisco Network Assistant saves topology changes in XML format in your work space.  use system START -> Rick click mouse Menu -> EXPLORE.  This should open a window in C:\Docs and Settings\.  Please make sure you have permissions to read/write the .networkassistant folder by right mouse clicking and opening properties, security TAB.  In the "communities" folder should be a XML file named after your CNA community name.
Thanks-
Afroz
[Do rate the useful]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Thanks-
Afroz
