03-25-2014 02:52 AM
Hi Guys,
we are using PI 1.3.
PI monitor and manage several switches. (about 30 devices)
I want to review the configuration of the switches with a text editor so it would be great if I could access the configuration files which PI creates by the background task "switch inventory".
Does anyone know where the PI store these files?
Thanks and Regards, Alexander
Solved! Go to Solution.
03-25-2014 03:13 AM
Hi Alex,
Check the below post ,hope it will answer your query :
https://supportforums.cisco.com/discussion/11852236/pi-where-devices-archive-files-are-located#3975460
Thanks-
Afroz
***Ratings Encourages Contributors ****
03-25-2014 03:13 AM
Hi Alex,
Thanks-
Afroz
