Community Member
where prime saves configuration files of switches from invetory
Hi Guys,
we are using PI 1.3.
PI monitor and manage several switches. (about 30 devices)
I want to review the configuration of the switches with a text editor so it would be great if I could access the configuration files which PI creates by the background task "switch inventory".
Does anyone know where the PI store these files?
Thanks and Regards, Alexander
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hi Alex, Check the below post
Hi Alex,
Check the below post ,hope it will answer your query :
https://supportforums.cisco.com/discussion/11852236/pi-where-devices-archive-files-are-located#3975460
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
1 REPLY
Hi Alex,
Thanks-
Afroz
55
