Where to check netflow data in cisco PI 1.3
I have done the configuration as per the Deployment guide.
As per the deployment guide to check the netflow data I have to check Design > Monitoring Templates and see if there are multiple NetFlow instance ( I think I need to go to Design> Monitoring configuration there is no monitoring templates)
Multiple netflow instance where will I find is it the Flexible netflow template?
Also want to know how will I find out the template has been successfully deployed and netflow data is receiving in the prime.
What is the template ID in the netflow templates how we can assign the template ID to the device.
Please advice.
178
