Webcast-Catalyst9k
Why less DRAM in cisco routers/switches
Nowdays memory has been so cheap.Why don't the cisco routers/switches support memory such as 1 GB ?
I know that high end routers/switches do but why can't cisco get this in the low-end products also , i don't think it will affect cost to much larger extent
Re: Why less DRAM in cisco routers/switches
Any cisco persons here to answer?
Try to post in the LAN switching/routing forum to see if you get an answer. You may not as this is more of a product design/enhancement issue.
97
