why whats up gold required
hi
well i am very new to cisco works .if any body can help me in getting some good ebooks on ciscoworks that will be very helpful to me .well in my lab i have 6 routers and cisco works cd one installed.can any body tell me what config on routers needed so that i can monitor the status of the link up and down on NMS. thanks in advance
1 REPLY
Re: why whats up gold required
You may want to configure this under the per interface command prompt: -
snmp trap link-status
E.g.
Router(config)# interface bri 0
Router(config-if)# snmp trap link-status
Hope this helps ;)
99
