WLC 2504 in Prime Infrastructure NetFlow problem
Hi there,
I am demoing a 2504 Wireless Lan Controller and am trying to get AVC monitoring set up in Prime Infrastructure 2.1 with base, Lifecycle and Assurance licensing (also a demo). I have added the 2504 to PI and can get snmp traps, configuration, etc ok but I am unable to get NetFlow working. I think it is because I am unable to assign an Assurance license to the device. I tried to assign a license to the device but it doesn't even show up in the assurance licensing tool.  What am I missing here?
Tom
1 REPLY
Hi Tom,Have you seen this
Hi Tom,
Have you seen this Guide on CCO
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/115756-avc-guide-00.html
Under Administration > Data Sources you should see the WLC sending flow to Prime.
Its also worth checking via the CLI on the PI box with TCPDUMP that you are seeing flow coming into the box.
284
