writemem by snmp
How can i achieve a WriteMem or Copy Run Start by SNMP for IOS verion 12.0 and newer (ie without using OLD-CISCO-FLASH-MIB but another mib supported ) ?
Thx a lot
1 REPLY
Red
Re: writemem by snmp
You may use the CISCO-CONFIG-COPY-MIB
The following assumes that the ip address of the device is 10.10.10.10 and the SNMP read-write string is private:
snmpset -v 1 -c private 10.10.10.10 .1.3.6.1.4.1.9.9.96.1.1.1.1.14.333 i 5
snmpset -v 1 -c private 10.10.10.10 .1.3.6.1.4.1.9.9.96.1.1.1.1.3.333 i 4
snmpset -v 1 -c private 10.10.10.10 .1.3.6.1.4.1.9.9.96.1.1.1.1.4.333 i 3
snmpset -v 1 -c private 10.10.10.10 .1.3.6.1.4.1.9.9.96.1.1.1.1.14.333 i 1
If you have the MIBs loaded properly, the commands would be:
snmpset -v 1 -c private 10.10.10.10 ccCopyEntryRowStatus.333 i 5
snmpset -v 1 -c private 10.10.10.10 ccCopySourceFileType.333 i 4
snmpset -v 1 -c private 10.10.10.10 ccCopyDestFileType.333 i 3
snmpset -v 1 -c private 10.10.10.10 ccCopyEntryRowStatus.333 i 1
162
