WS-SVC-NAM-2 upgrade from 3.4(1a)
Dear All,
            I have WS-SVC-NAM-2 with following details.
NAM application image version: 3.4(1a)
Maintenance image version: 2.1(3)
NAM Daughter Card Micro code version: 1.34.1.27 (NAM)
BIOS Version: 4.0-Rel 6.0.9
Installed patches:
No patches are installed on this system.
I need to upgrade to latest application inage i.e. 5.1.x
As 3.4(1a) is EOL since long time and to upgrade it to the latest I need to first upgrade my exisiting image to 3.6, but on cisco software download page for NAM-1/NAM-2 application image I counld not found 3.6x.
So can someone tell me how to upgrade to 3.6x from exisiting 3.4(1a) for latest upgrade ?
Thanks & Regards
Ahmed...
Everyone's tags (1)
Re:WS-SVC-NAM-2 upgrade from 3.4(1a)
I got confirmation from Cisco that I can't upgrade from 3.4(1a) to 3.6 or 4.x as both softwares are EoL.
I need to install fresh configuration with 4.x.
Even 3.6 & 4.x can't be upgraded to 5.x.
Sent from Cisco Technical Support Android App
i have the same query, i want to upgrade "WS-SVC-NAM-2" from 3.4(1a) to the lates version " 6.0.2"
1. can i upgrade directly or i need to upgrade to version 4 or 5 ?
2. can upgrade this module by GUI "WEB" or only command.
3. can you give the procesure for upgrade?
this module doesn't have any configuration like new, long time installed  but no one use it
Hi Ahmad and steven,
NAM 3.4 and 3.5 is way old NAM application Image. Development team does not support it.
even they don't recommeneded to use 4.2 as there are few challanges with NAM 4.2 Image as well..
I would suggest to go directly for  6.x  or 5.x .
Here  is the download link :
http://software.cisco.com/download/release.html?mdfid=277991104&softwareid=282700108&release=6.0.2&relind=AVAILABLE&rellifecycle=&reltype=latest&i=rm
NOTE : you would need 2 GB of RAM  on NAM for this upgarde
use the below link for Image upgarde:
http://www.cisco.com/en/US/docs/net_mgmt/network_analysis_module_software/5.1/switch/configuration/guide/advcfg.html#wp1035516
IMP : use the
--install
keyword clears  and recreates all of the NAM partitions; this action is similar to  restoring the factory-default state. If you use the
--install keyword, the previously stored reports and data (if any) will be lost
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Aforz,
i am really appreciayed your cooperation, i have one question regarding the RAM, in show tech i have this output
show version
Maintenance image version: 2.1(2)
Installed patches:
show memory
Installed:      990 MB
Available:      727 MB
System Usage:   262 MB
can i upgrade upgrade to latest version 6-0-2  directly ? and from the above memory is it the RAM is enough ?
becuase you mentioned need 2G
Hi Steven ,
You may be able to upgarde ,however you need to have 2GB of RAM for the optimum performace of NAM module.
Thanks-
Afroz
Hi Afroz,
you mean i have enough RAM for upgrade, but regarding 2 GB is it Mandotary or only for performance ?
You might be able to upgarde but 2GB is recommended
Thanks-
Afroz
Hi Afroz,
i am really appreciate for your cooperation, so i will upgrade with the same RAM if the customer doesn't want to buy 2 GB and i will not see any issue,
i have another queery  you mentioned i have to use install do you mean i need to use it in this command
root@localhost# upgrade ftp-url --install
am i right?
Yes ..that is correct
Thanks-
Afroz
HI,
thans alot
i will upgrade with the same RAM because the customer doesn't want to buy 2 GB, i hope i will not face an issue
thanks again
Re: WS-SVC-NAM-2 upgrade from 3.4(1a)
Hi ..
I am gald  that my post was helpful for you !!!
Thanks-
**Rating Encourages contributors **
Hi Ahmad,
              I will be upgrading NAM application version to 5.1.2, I searched many cisco documents, but did not found anything useful how to install NAM application [NOT UPGRADE] as I can not upgrade to 5.1.2 from any 3.x or 4.x version.
I found your comment helpfull to to use --install to installl rather than upgrade.
Can you please confirm that --install will install rather than upgrade ?
Thanks & Regards
Ahmed.
Hi Ahmed,
****Upgarde procedure keep the Old data and take you you to the New version *******
This  is an Upgarde Procedure ,however  if you use the  --install command during the Upgarde Procedure ,it will wipeout the old data and NAM will be like a factory Installed and then it will upgarded to New Version.
Follow the below link ,in the step 5:
Step 5 Upgrade the NAM application software as follows:
DON NOT USE THIS
where ftp-url is the FTP location and name of the NAM software image file
or
USE THIS ONE
Note The --install keyword clears and recreates all of the NAM partitions; this action is similar to restoring the factory-default state. If you use the --install keyword, the previously stored reports and data (if any) will be lost.
IMP :: It is recommended to have 2GB RAM for running 5.x image
Thanks-
Afroz
Hi Afroz,
how are you, hope you are doing well, i have one question, if i want to upgrade nam module from current version 3.4(1a) to version 4.2, do i need fresh installation or i can do normal upgrade?
can i use GUI for upgrading or only way by using commands line?
thanks agian:)
Hi Steve,
It can be done only via CLI .
and you need to do a Fresh installed ,if you are moving from 3.4 to 4.x
Thanks-
Afroz
Hi Afroz,
thanks for quick answer and i will the same above steps.
thanks
950
