Community Member
XML for Nexus7010
Can aynone tell me if there is a way to automatically script an XML from entering a Cisco command.
Just learning about XML , and so far , I,ve SSH2 to a Nexus7000 and can run some example XML scripts that were given on the Cisco website, but I was wondering if there  was a convertor which enables you to enter the command you want to convert to XML and produces the XML.
1 REPLY
Community Member
Re: XML for Nexus7010
Any ideas from thr teckys ?
I understand XML can do any commmand , as if you were logged in and running conf t ...I can see there are schema's on the CCO but would like to know if there is a quick an easy way to transate 'what I'd like to do' into the XML
233
