Excessive connect/disconnect from OnPlus to my ESW switches
         I started experiencing problem with some phones rebooting.  So I went into my switch logs (I have 4 ESW-540-24P) and noticed the OnPlus logs into the switch every 2 minutes for 5 seconds and quits.
2147461897 14-Aug-2012 14:52:55  Informational %AAA-I-DISCONNECT: http connection for user xxx, source 192.168.2.27 destination 192.168.2.22 TERMINATED
2147461898 14-Aug-2012 14:52:50  Informational %AAA-I-CONNECT: New http connection for user xxx, source 192.168.2.27 destination 192.168.2.22 ACCEPTED
My logs are totally filled by those connect/disconnect eliminating all important info.  The phones rebooting are probably not related to this connect/disconnect because I have other phones on other switches working fine.  I'm still curious if this is normal behavior.
Thank you
Sorry forgot to update this thread.
A firmware updated solved the issue.
Bronze
Thanks for the update.
211
