11-26-2013 11:47 PM
Hi All,
I have several Cisco 3560C setup at multiple stations. The Cisco 3560C are connected in a daisy chain between each other using 100BASE-BX10-D and 100BASE-BX10-U SFP. So, on the first Cisco 3560C (station 1), I have a U-type connecting to the second Cisco 3560C (station 2.). The second Cisco 3560C (station 2) will have a D-type and U-type SFP where the D-type connects to the previous station 1 on its U-type SFP. This setup repeats for station 3 onwards.
It seems that these connections between the stations, I noticed that the Cisco switch registers the link at 100Mb half-duplex and I see incrementing CRCs and collisions. I am not able to hard-code the interface to 100Mb FULL as it seems that the interface configuration does not give me the option to do a 'speed 100' or 'duplex full'.
Is this normal for these kinds of SFP?
Below are some outputs:
Cisco IOS Software, C3560C Software (C3560c405-UNIVERSALK9-M), Version 12.2(55)EX3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 10-Aug-11 07:37 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02100000
Switch(config)#do sh int status
Port Name Status Vlan Duplex Speed Type
Fa0/1 notconnect 15 auto auto 10/100BaseTX
Fa0/2 notconnect 15 auto auto 10/100BaseTX
Fa0/3 notconnect 15 auto auto 10/100BaseTX
Fa0/4 notconnect 15 auto auto 10/100BaseTX
Fa0/5 connected 15 a-full a-100 10/100BaseTX
Fa0/6 notconnect 15 auto auto 10/100BaseTX
Fa0/7 notconnect 15 auto auto 10/100BaseTX
Fa0/8 notconnect 15 auto auto 10/100BaseTX
Fa0/9 notconnect 15 auto auto 10/100BaseTX
Fa0/10 notconnect 15 auto auto 10/100BaseTX
Fa0/11 connected trunk a-full a-100 10/100BaseTX
Fa0/12 connected trunk a-full a-100 10/100BaseTX
Gi0/1 connected trunk a-half a-100 100BaseBX-10U SFP
Gi0/2 connected trunk a-half a-100 100BaseBX-10D SFP
Switch#sh interfaces gigabitEthernet 0/2
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is c025.5c11.928d (bia c025.5c11.928d)
Description:
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 254/255, txload 1/255, rxload 1/255
Keepalive not set
Half-duplex, 100Mb/s, link type is auto, media type is 100BaseBX-10D SFP
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 80000 bits/sec, 22 packets/sec
5 minute output rate 16000 bits/sec, 16 packets/sec
74931 packets input, 21611558 bytes, 0 no buffer
Received 48734 broadcasts (39982 multicasts)
667 input errors, 667 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 39982 multicast, 0 pause input
23385 packets output, 3857612 bytes, 0 underruns
0 output errors, 564 collisions, 1 interface resets
0 babbles, 29 late collision, 0 deferred
11-26-2013 11:58 PM
Possible fault with your fibre. The value should be "255/255" and nothing else.
This will explain your high CRC.
As to your duplex, I have no experience using the BX SFP so I don't know why your link has negotiated to "half duplex".
Can you change the settings of the interface to full duplex?
11-27-2013 12:06 AM
It is not just one fibre. All adjoining stations on the 100BASE-BX10 SFP are showing me 100 half-duplex.
11-27-2013 12:08 AM
In my opinion, you have two issues:
1. You could have a faulty fibre optic link; and
2. Half-Duplex.
12-01-2013 08:43 AM
Yes scope all connections with a 900 micron 200x scope, and clean anything you can.
GLC-FE-100BX-U | 100BASE-BX10-U | -8 | -14 | -3 | -28.2 |
GLC-FE-100BX-D | 100BASE-BX10-D | -8 | -14 | -3 | -28.2 |
If its clean, check the TX/RX power levels with a power meters. End-to-end; bidirectional test, on both lamdas.
Because of the CWDM going on, I'm not sure I'd trust the internal "show hard" or
"show interfaces interface-id transceiver detail" internaly.
Obviously this is something common/systemic since it happens betwen multiple locations.
Is the fiber the common denominator?
12-01-2013 01:50 PM
You might try the following commands, to see if you can get the interface to be release the a-half duplex mode.
media-type gbic
no negotiation auto
