Community Member
10gbit/s ports not working
my problem is:
I have 2x catalyst c3560e-48TD-S (Image: c3560-universal-M). I need to interconnect this switches by 10Gbit ports. We are using X2-10GB-LRM modules.
After inserting modules, 10Gbit ports are in err-disable state with a reason gbic-invalid. Media type is unknown.
Where is the problem? .... i need to configure something or these are incompatible devices or something else ? :(
Thanks.
2 ACCEPTED SOLUTIONS
Community Member
Re: 10gbit/s ports not working
please check the 10-Gigabit Ethernet Transceiver Modules Compatibility Matrix for the right IOS Version.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.html
regards
Udo
You need to upgrade the IOS software or another option might be to to use another X2 transceiver module compatible with your current IOS release. Compatibility document indicates the following modules are compatible with your software and standard Multimode fiber:
X2-10GB-LX4 (300Meters)
X2-10GB-SR (26 Meters)
X2-10GB-CX4 (15meters copper).
This will depend on the distance between your switches.
Community Member
regards
Udo
Community Member
i found for model WS-C3560E-48TD is needed :
Catalyst Operating System: -
Cisco IOS Release for module X2-10GB-LRM
: 12.2(40)SE
My current version is: 12.2(35)SE5 ( ipbase license) .... so i need to upgrade my IOS?
Thanks.
Community Member
Thanks. ;)
395
