10Gig - GBIC module, can we connect?
I have a PIX 535 firewall which has GBIC module and I need to connect to a Switch 2360 / 2960  which has 10 Gig SFP.
Can I connect using multimode fiber.   Will it work?
Or is there any Speed configuration we can do to reduce 10 Gig to 1 Gig in the switch side?
Thanks & REgards,
Lenin. S
96207 45656
Everyone's tags (5)
1 REPLY
Hi I beleive the PIX interface is fixed at 1GigE and with a 10GE SFP in the switch this configuration won't work, you need to ensure the devices are matched for the same speed and media type Multi Mode (MM) or Single Mode (SM).
I beleive the PIX GE interface is MM so you will need to install an MM 1GE SFP into the switch don't forget that you will also need a GigE Failover Link if you are using PIX Failover.
Chris
1582
