15305 and 15454 Ethernet interworking
Hi Folk,
Wonder if anyone can help out there.
Would like to provide a LAN Extension service over an SDH network. Does anyone know whether the GigE and FE cards on the 15305 interwork with the 15454 CE or ML ethernet cards?
Have looked on the Cisco site and am somewhat confused. The 15305 uses GFP-F to map Ethernet into SDH. The 15454 cards appear to encapsulate the ethernet frame before it uses GFP-F.
Could someone enlighten me!!
Phil
1 ACCEPTED SOLUTION
Bronze
Re: 15305 and 15454 Ethernet interworking
Hi Phil
yes, of course they do. You have two possibilites. You can use the 15305 modules in L1 mode and connect them to the CE cards on 15454. Or you can use the 15454 ML cards, maybe with a L2 RPR ring. Then you can switch the 15305 modules to L2 mode with a integrated L2 switch.
CE cards anf the 15305 modules in L1 mode is always P2P and pure ethernet transport without any L2 or VLAN stuff.
ML card and 15305 modules in L2 mode use a L2 switch with a lot of L2 features, like VLAN, STP, QoS and so on.
By the way, both CE and 15305 modules in L1 use GFP-F and are fully compatible.
I hope this helps. Please rate all posts.
Cheers
Rene
Bronze
Hi Phil
Cheers
Rene
Thanks Rene - that is a very helpful.
Cheers,
Phil
I have not tested interoperability myself, but I believe it should work fine. The only issue to be aware of is that the multiframe indicator must be "enabled" even though only running single vc. If it is not possible to configure this in the 15454, configure a minimum of 2xVC in the VCG. E.g. VC-3-2v for the EoS circuit.
Thanks for the reply.
Phil
188
