15454 BLSRs
With the newer releases is it possible to do a 4 fiber BLSR (or) 2 seperate oc48 2 fiber blsr's in the same shelf?
With the 10G 15454 can you do multiple oc48 2 fiber BLSRs in the trib slots?
1 REPLY
Bronze
Re: 15454 BLSRs
The following specifications are defined for the G1000-4 card:
Part Name: 15454-G1000-4
Part Number: 800-08578-01
CLEI Code: SNP8KW0KAA
G1000-4 cards are equipped with four GBIC connectors used for optical cable termination. GBICs must be ordered separately. The G1000-4 cards are rated at 62 watts per card and operate at ambient temperatures ranging from -5 degrees Celsius to +55 degrees Celsius.
Before you install the G1000-4 card to an ONS 15454 node, the node must be running Release 3.2 software or greater, must be provisioned with TCC+ cards, and must be provisioned with the XC10G card in the new (Release 3.1) ANSI shelf. If a G1000-4 card is inserted into a node that is provisioned with either XC or XCVT cards, the new card will not be recognized. Both high-speed slots and low-speed slots support the G1000-4 card. The high-speed slots are 5, 6, 12, and 13. The low-speed slots are 1-4 and 14-17.
Try:
http://www.cisco.com/en/US/products/hw/optical/ps2006/prod_release_note09186a008009172b.html
120
