Community Member
BLSR with DCC's disabled?
Has anyone attempted to run a BLSR with DCC's turned off? Need to segment a large subnet on a 454 network. If you can run a multi-vendor BLSR shouldn't you be able to run an all 454 BLSR with select DCC channels turned off to acheive network segmentation.
1 REPLY
Anonymous
N/A
Re: BLSR with DCC's disabled?
For BLSR to work you need to leave DCC turned on. Because payload table needs to travel across DCC for traffic to be delivered.
183
