Webcast-Catalyst9k
bug id CSCsm50360
I am being told by a customer they have this issue, but I can find no data on this id. Anyone know anything about it, I have tried the bug toolkit no luck.
Re: bug id CSCsm50360
No problem found out what I need to know, for ref:
There is very little description in there, only it says
what was discussed on the conf call - that an ONS15454 10DME card
may exhibit small amount of egress bit errors at 1G or 4G speeds.
Hence we are seeing Invalid Transmission Words and Disparity Errors
on the MDS, resulting in FC frame CRC errors.
This type of issue should be worked through Cisco's Technical Support group.
212
