C2960-24TC-L + Singlemode fiber
Hello
I need to know if this architecture is compatible.
I put the diagram as an attachment.
Thanks !
Thibaud.
  • Optical Networking
1 ACCEPTED SOLUTION
Yes, the GLC-LH-SMD is compatible with your hardware:
Catalyst 2960 series
WS-C2960-24TC-L
WS-C2960G-24TC-L
WS-C2960-48TC-L
GLC-T (1000BASE-T)
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
GLC-ZX-SMD
GLC-BX-D
GLC-BX-U
CWDM SFP
GLC-SX-MMD
GLC-LH-SMD
12.2(25)FX
Optical Transceiver module compatibility information can ba found at the following Cisco url:
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_device_support_tables_list.html
Some of the optical transceiver model numbers shown in the above table are being discountinued, per the following Cisco presentation:
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6577/presentation_c97-683584.pdf
Hope this helps!
To run the proposed link over single mode fiber, you will need to use the GLC-LH-SMD optical transceiver in the 2960s and single mode fiber jumpers (LC to ST connectors), between the module and the patch panels.
The GLC-SX-MM optical transceiver is for operation over multimode fiber.
thank you for your response Tom
GLC-LH-SMD is compatible with the C2960-24TC-L ?
WS-C2960-24TC-L
WS-C2960G-24TC-L
WS-C2960-48TC-L
GLC-T (1000BASE-T)
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
GLC-ZX-SMD
GLC-BX-D
GLC-BX-U
CWDM SFP
GLC-SX-MMD
GLC-LH-SMD
12.2(25)FX
Hope this helps!
great !!
Thank you very much for the information. Now I know what modules I need.
What is strange is that I tested rapidly the architecture of my schema and it seems to work. At least, a ping works.
This is not necessarily the most efficient or the most relevant but it seems to work.
510
