Community Member
Can't clear PM stats
I am trying to clear PM stats on a DS3XM12 card and I keep getting the EID-3222 message "could not clear stats". I am on REL 7.0.0. What can I do to resolve this??
Community Member
Re: Can't clear PM stats
The command to clear the statistics are
Type: clear counters
Press ENTER a couple of times
Community Member
did you try using tl1?
init-reg-t3::fac-?:ctag;
Community Member
This seems to be a bug with 454 sw. I think you should check release notes, or request TAC support. Cisco should provide a path of this issue.
221
