Can't get SFP-10G-SR to work
I recently purchased two SFP-10G-SR SFP+ modules and I can't seem to get them to work at all in my WS-C3650-PD48-S
I put the SFP into either 10 Gigabit port and I see this on the console:
Jul  1 00:16:18.527: %PLATFORM_PM-6-MODULE_INSERTED: SFP module inserted with interface name Te1/1/4
But the interface never actually comes up. I don't get any additional messages in the log or the console (I had "logging console 7" set). I'm using a Cat6a cable. I see this when I do a "show interface TenGigabitEthernet 1/1/4"
TenGigabitEthernet1/1/4 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is e4aa.5d99.8834 (bia e4aa.5d99.8834)
  MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
  Keepalive not set
  Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-SR
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 884 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
I've tried both of my SFP modules in both of the 10GB ports and I also get the same result. Any idea's why this won't work? It is listed as a supported module for the 3650: http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html#_Toc485827262
I've also tried doing what is suggested here
I've tried both my SFP's in both my switches, so I don't think it is a faulty switch or SFP. I've also tried multiple Ethernet cables.
Joshua
  • Optical Networking
Hall of Fame Super Gold
SFP-10G-SR
SFP-10G-SR
SFP-10-SR?  Cat6A?  Ethernet?
How is that possible you were able to use a copper cable into an SFP+ port that will only accept fibre optic cable?
It's not fiber, its copper:
https://www.amazon.com/10Gtek-Compatible-Gigabit-Transceiver-10GBase-T/dp/B01KFBFL16/ref=sr_1_1?ie=UTF8&qid=1498943516&sr=8-1&keywords=sfp-10-sr+copper
Are you saying that Cisco doesn't support Copper 10GB, only fiber?
My data center provider, only gives me copper connections. What would be the proper way to connect their uplink to the 10GB switch?
Only fibre.
Cisco-supported SFP+ modules can be found HERE.
