Curt,
When changing a OC-48 1550 LR to an OC48 1310 IR you do not need to delete and re-add the card. As long as both cards have the same port count, simply swap them out.
If the cards have a different port count, you need to follow the procedure below.
http://www.cisco.com/en/US/docs/optical/15000r9_0/15454/sonet/procedure/guide/454a90_upgcardspan.html#wp1132039
BTW - You cannot delete a card until all underlying services have been deleted.
For example, All circuits, DCC, timing has to be de-provisioned before the card can be deleted.
Hope this helps,
Steve Noyes
CSE Cisco TAC
