Community Member
Cisco 15454 2F BLSR interoperability with the Nortel LH combiner platform
Help anyone, my problem is the following:
The company I work for is interfacing with another company that is running a 2 Fiber BLSR topology with the ONS 15454. This device will be interfacing with our existing Nortel LH combiner platform running version 2.0. When we dicussed this application with Nortel, they told us that the Cisco 15454 will not interface with the Nortel LH combiner cards due to the fact that the Cisco 15454 two fiber BLSR implementation is proprieitary and not standards compliant in that it requires use of the K1 byte of the second STS-1. Basically, the Nortel combiner cards are not transparent to the second STS-1, so the K1 value input is losted. They claim they did not have this issue with other vendors' BLSR SONET devices, just Cisco's 15454.
Another way they decribed the problem was: "The Nortel LH combiner cards do not work with the 15454 BLSR topology because of a proprietary overhead usage conflict. The Cisco product uses an undefined overhead byte for a BLSR check sum which conflicts with Nortel combiner mapping of tributary defined overhead into unused overhead of the aggregate line."
I do not know what software version Nortel was running when they did this testing with the ONS 15454, but I thought maybe someone has heard this one before and that maybe Cisco corrected this problem with a later release. Help anyone!
Community Member
Re: Cisco 15454 2F BLSR interoperability with the Nortel LH comb
DCC Interoperability is crucial to setting up the 2F BLSR . Unfortunately DCC's between different vendors don't communicate with each other. This would be the primary reason as to why a 2 F BLSR cannot be setup between SONET equipment from multiple vendors. ( The same issues are applicable for Cisco , Redback Networks , NEC ... )
However , linear 1+1 protection schemes do interoperate with multi vendor equipment and should be the most feasible protection mechanism that you may want to attempt .
- P.
Community Member
I agree with you, however, the Nortel LH platform is a DWDM platform, not SONET. I have personally run Redback's SmartEdge 800 in a BLSR topology over the Nortel LH platform without any issues, so I am still a little confused. I appreciate your input. I am working on getting Cisco to comment. If I get an "official" answer, I'll post it. Thanks again.
Community Member
K3 Byte remapping is required...
"The ONS 15454 uses the K3 overhead byte for BLSR automatic protection switching (APS) to allow an ONS 15454 BLSR to have more than 16 nodes. If a BLSR is routed through third-party equipment that cannot transparently transport the K3 byte, you can remap it to either the Z2, E2, or F1 bytes on OC48AS cards."
Cisco allows more than 16 nodes in a BLSR but the K1 byte only has 4 bits available for 16 nodes. Cisco has extended this range of Node IDs which is proporietary to Cisco. However, I believe if the ring does not exceed 16 nodes then the 15454 complies to Telcordia standards...
Community Member
you can adjust the dcc framing size for the vendors and interface any vendor equipment with each other. If this is a problem you are still working contact me I will be happy to explain how. I have encountered this on many customer networks.
