Cisco 15454 MSTP - Acceptable error loss
patrick.roche
Dear all,
What does Cisco say is an acceptable Packet loss/CRC check for the following set-up?
I have a link between 2 Cisco 15454 MSTP cards which in turn plug into a tenGig XENPAK which are both housed in 6509s.
I've noticed the following errors:
79 input errors, 39 CRC, 39 frame, 0 overrun, 0 ignored
Mod Ports Card Type Model Serial No.
2 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL093487FN
SwitchXXX#sho int ten 2/2
TenGigabitEthernet2/2 is up, line protocol is up (connected)
Hardware is C6k 10000Mb 802.3, address is 0014.f191.b800 (bia 0014.f191.b800)
Description: ** DWDM to core - ten 1/1 **
Internet address is 10.141.196.25/30
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 10Gb/s
input flow-control is off, output flow-control is on
Last input 00:00:22, output 00:00:01, output hang never
Last clearing of "show interface" counters 5d23h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
L2 Switched: ucast: 315 pkt, 45426 bytes - mcast: 36667 pkt, 3599775 bytes
L3 in Switched: ucast: 3470134 pkt, 1546021811 bytes - mcast: 59801 pkt, 24634
255 bytes mcast
L3 out Switched: ucast: 3603213 pkt, 2424726923 bytes mcast: 0 pkt, 0 bytes
3654653 packets input, 1585903250 bytes, 0 no buffer
Received 183968 broadcasts (85896 IP multicast)
0 watchdog, 0 multicast, 0 pause input
4071365 packets output, 2468656212 bytes, 0 underruns
rtappend_2
Are these DWDM XENPAKs direct into MSTP DWDM layer, or LR XENPAK into transponders?
I will find out.
Hi There,
We have LR XENPAK into transponders
