03-15-2012 02:07 PM
Have what I hope is a simple question for you. How best to connect my 250 Mbit/s internet circuit to a newly arrived Cisco 2911? We're changing over our internet circuit from being managed by AT&T (includes router) to an unmanaged one (we provide router). The existing demarc extension terminates in a mult-mode LC connector and connects to a SFP module in the managed AT&T router.
Was sent a 2911 with no additional modules or cards. I have some GLC-SX-MM= SFP modules, but did not see any SFP slots in the 2911. Do I have to go with a higher router, like the 2921? Or are there SFP carrier cards or other modules we can use from Cisco? Thanks.
Scott
03-16-2012 03:16 AM
I think you need an HWIC-1GE-SFP interface card, data sheet says the GLC-SX-MM is supported in the HWIC, make sure you have the minimum software image (15.0(1)M) and package (IP Base) loaded on the 2911 router.
Link to data sheet which should answer all your questions:
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd8016be8d.html
Chris
03-16-2012 03:38 AM
For the ISR G2, like the 2900, you should be looking for the EHWIC-1GE-SFP-CU.
However, the main question is this: Can a 2911 handle 250 Mbps bandwidth? The answer is no. The 2911 can handle 180.73 Mbps of traffic. This value is express in HALF duplex and without any encryption.
I believe a 3925E can support 250 Mbps of traffic (full dupex, full encryption).
03-16-2012 05:05 AM
Appologies for missing the 250Mbs requirement I was to busy focusing on the SFP.
Chris
