Cisco XENPAK - HP2910 10GB interface
We need to connect a Cisco XENPAK-10GB-LR module with a "HP ProCurve 2-Port 10-GbE SFP+ al Module (J9008A)" (a module inside a
"HP Switch E2910-48G al(J9147A)")
The HP switch module would have an "HP X132 10G SFP+ LC LR Transceiver (J9151A)".
Where can I find some info if this kind of fibre connection is supposed to work ?
The specifications for both the devices (XENPAK and the HP module/tranceiver) are same - 10GBASE-LR (single-mode fiber, 1310 nm).
Florin
Everyone's tags (3)
1 ACCEPTED SOLUTION
Yes, the two transceivers will interoperate.
Make sure you order the correct singlemode fiber patch cords to interface to the LC/UPC connector type on the HP transceiver and the SC/UPC connector type on the XENPAK.
1 REPLY
971
