Webcast-Catalyst9k
Compatibility of MGBSX1 with GLC-SX-MMD
My query to all of you is;
If I connect a GLC-SX-MMD on a Cisco 2960S switch at one end and MGBSX1 on a SG300-28 SMB switch at the other end, will the link come up? Are these different types of modules interoperable?
Can I use VLAN truncking through this link betwnne these two different switches?
Green
MGBSX is supported with GLC
MGBSX is supported with GLC-SX-MM and SFP-GE-S, so yes, the link should come up and yes you may use trunking between both switches without problems - assuming you understand the configuration of the SG300.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom, do you have the web
Hi Tom, do you have the web link that supports that information? thank you!!
450
