Community Member
Compatibility SFP
hello,
I currently have several Cisco C2960X-24TD-L. I would savois it is possible to interconnect two SFP GLC-SX-MMD and GLC-LH-SMD with a multimode cable.
Where the light switch is connected to the GLC-LH-SMD lights but the GLC-SX-MMD does not light. Will he make an order?
kind regards
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Not possible.  Both modules (and associated cables) must be of the same wavelength.  It's either GLC-SX-MMD-to-GLC-SX-MMD (with Multi-Mode cable) or GLC-LH-SMD-to-GLC-LH-SMD (with Single-Mode cable).
it seemed that the SFP GLC-LH
it seemed that the SFP GLC-LH-SMD could do both singlemode and Multi-mode.
1.  State your source where you formed your conclusions from.  I'll poke holes in it faster than a buckshot.
2.  Do you know how much each SFP cost?  I hope you do because if you try this stunt, you'll be permanently "burning" the optics of the LH module (after prolong use).
Community Member
Thank you for your reply, it
Thank you for your reply, it seemed that the SFP GLC-LH-SMD could do both singlemode and Multi-mode.
So if I understand this is only for the cable, can you confirm ?
Community Member
Thank you again for your
Thank you again for your answers. To my sources, this is a colleague who ordered thinking that it would work ... We know how expensive SFP but really thought it was possible to connect SFP GLC-LH-SMD to GLC-SX MMD.
We are not experts in optics we cope as we can. Now that the mistake is made, we will make do. ;)
1.  We all mistakes.  You should see what I've done.
2.  Did you open the boxes to the wrong SFP?  If no, you still have a chance to return the component.   If you have, did you open the plastic bag?  If no, you still have the chance to return the component.
Neither am I when I started but if you read some of Tom's or Marvin's posts/responses, you will be.
Hall of Fame Super Silver
Thanks Leo - we all stand on
Thanks Leo - we all stand on the shoulders of giants. :)
Community Member
Now I know that this forum
Now I know that this forum exists, I would do it   ;)
Community Member
Hi Leo, May I know what kind
Hi Leo,
May I know what kind of Fiber Patch cord can use for GLC-SX-MMD=.
1. SFP to SFP
2. SFP to ODB
(for example LC to ST type for ODB to SFP,...)
thank you,
Kaung
Kaung,The GLC-SX-MMD=
Kaung,
The GLC-SX-MMD= transceiver requires a duplex LC connector on the patch cord end that plugs into it.
The Optical Distribution Box (ODB) end of the connection is dependent on what type of patch connectors are installed there. The ODB refers to the enclosure and does not specify the type of mechanical plugs for the fiber that it houses.
They are often ST type but you need to inspect them visually and/or confirm with your provider or fiber installer what type are installed and order patch cables accordingly.
291
