07-02-2008 11:32 AM
Hi All,
We are exploring a possibility to connect a 2.5G output from a DWDM node to 7600 router having a 10Gig xenpak module. Is this possible ?
Any help is really appreciated
Anantha Subramanian Natarajan
07-02-2008 12:49 PM
A 2.5G interface cannot be connected directly to a 10G interface.
What are you trying to accomplish?
07-02-2008 01:38 PM
We are trying to use the esiting 10Gig port as temporary solution to connect a 2.5g or even 1 Gig output from the DWDM.
Any help would be really appreciated
07-02-2008 02:00 PM
This would be no differet than plugging a 100Base-FX port into a 1GigE port. It just can't be done without some type of mediation device (switch, router, other?).
It is not clear what your network looks like so it is challenging to propose solutions.
07-02-2008 02:15 PM
Ok thanks
