Connecting 3750X via fiber
wadereinhard
We have four 3750x Ci
sco Switches.  We would like to connect our database server
to the switch via fiber connection. What would we need to purchase to do this?  We have the Cisco 3750x-48T-S.  We do not have any of the additional network modules.
13 Replies 13
Tom Randstrom
If you are going to interconnect a switch with a RJ-45 UTP connection to server with a RJ-45 UTP connection (via fiber cable), you can purchase a media converter for each connection, which are available from many sources (I have provided one below).
Typical set-up
Switch/UTP interface ---> CAT-x ---> UTP interface/media converter/fiber interface ---> fiber ---> fiber interface/media converter/UTP interface ---> UTP interface/Server
You will need to know the following information:
- Port speed
- Fiber type (multimode or singlemode)
- Distance
- Connector type (easy to order a hybrid jumper to mate with the convertor)
- Managed or unmanaged
OMNITRON Media Converters
http://www.omnitron-systems.com/media_converters_unmanaged2.php
Let us know if you have additional questions.Hope this helps!
Tom
We are actually wanting to connect fiber directly from the server to the switch
- not using RJ45 cabling.  Would we need to purchase the network module with four GBE or two 10 GBE SFP+ interfaces?
If you are connecting to a GE server port, then you could use either Network Module.  According to the switch data sheet, the 2x 10GbE Network Module can be configured to support up to 4 GE ports (per table below):
Table 3. 10GbE Network Module Configuration
10GbE SFP+ Ports
GbE SFP Ports
The 10GbE module probably is more expensive, but provides some future-proofing if you upgrade the server to 10GbE in the future.
Thanks, that is what I thought.  I
then asked our hardware vendor for a quote for 4 10 GBE SFP+ modules.  He responded with
According to Mark, my engineer, you also need the SFP+  Do you know which one you need?
SFP-10G-LR= 10GBASE-LR SFP+ module
SFP-10G-SR= 10GBASE-SR SFP+ module
SFP-10G-LRM= 10GBASE-LRM SFP+ module
SFP-H10GB-CU1M= 10GBASE-CX1 SFP module
SFP-H10GB-CU3M= 10GBASE-CX3 SFP module
SFP-H10GB-CU5M= 10GBASE-CX5 SFP module
I responded ...
According to the documentation that came with the switches the Part #3KX-NM-10G contains the SFP+....
The Cisco Catalyst 3750-X Series and 3560-X Series Switches support an optional network module for uplink ports. The default switch configuration doesn't include the uplink module; the customer has the flexibility to choose from four GbE port (3KX-NM-1G) or two 10GbE port (3KX-NM-10G) network module at the time of switch purchase. The 10GbE uplink module features four physical ports with two SFP+ and two regular SFP ports. The SFP+ interface supports both 10GbE and GbE port, allowing customer to use their investment in GbE SFP and upgrade to 10GbE when business demands change, without having to do a comprehensive upgrade of the access switch. The uplink module is hot swappable. The 10GbE network module can be used in any of the combinations shown in Table 3.
I assumed for the 3750x there were only two options - those listed above.  I'll take a look and let you know.
Am I missing something?
Wade,
The Network Module (3KX-NM-10G or -1G) just provides the SFP/SFP+ module slots; you still need to add the SFP optical transceiver module(s).  The selection of the particular optical transceiver module is dependent upon the link speed, link length and link fiber type.
What type of optical interface is on your connected server? You need to match the optical interfaces on the switch port and the server.
Optical transceiver modules do not negociate link speed, so if you need 1GE, you purchase a GE SFP optical transceiver; and if you need 10GbE, you purchase a 10GbE SFP.
Interface Type - PCI Express x4
So, I've checked out some ofthe GBIC modules.  Am I correct in assuming the major difference in price is based on the maximum distance?
Yes, Wede. You're correct.
Just to your information the name GBIC is not more used. The right term now is SFP (Small Formfactor Pluggable).
You have SFP longwave, shortwave and CWDM that costs something like US$ 3500.00. CWDM are used to very long distances (60 KM). Longwave can be used to distances like 10 KM, 20 KM until 50 KM. It dependes of laser power.
The SFPs are cheaper ones that support smaller distances.
Hi Wade.
I have a doubt about your question?
Why do you want to change your current copper connection to a fibre connection? Is it about to have better performance? Is it about an eletromagnetic interference in copper cable?
What kind of protocol you want to use after those changes? Ethernet or Fibre Channel?
If your problem is about performance, you can improve it using a CAT6 copper cable.
If problem is about eletromagnetic interference, you are right to change your connection.
If you want to change protocol to Fibre Channel, you can't keep your switches. You will need a Fabric Switch.
We are upgrading our SAN and database server to fiber connections from SCSI.  We are doing this due to a growing number of users and speed issues.  We do not want to upgrade every connection in our environment - just those to and from the SAN and database.
Incorrect. Any type of copper cable will have the same exact performances in terms of speed, data transfer rate, etc.
They will have different electrical performances, but that is not of much interest for practical purposes.
Not said. One can use S-FTP cables to prevent EMI.
I have a similar situation here, am using a
WS-C3750X-48P-L switch, but what i need to know is what is the MINIMUM IOS FOR GBIC SUPPORT ?
thanks
Look on the transcevier Compatibility Information page, select the module speed (1GE or 10GE - depending upon the Network Module you are using - Table below) you will be using, then find the hardware part number (WS-C3750X-48P) that the transceiver will be installed in; the table will show you the minimum IOS software required to operate the optical module.
The WS-C3750X-48P does not have any pluggable interfaces - the Network Modules installed in the switch do.
C3KX-NM-1G
Four GbE port network module
C3KX-NM-10G
Two 10GbE SFP+ ports network module with four physical ports with two SFP+ and two regular SFP ports
C3KX-NM-10GT
Two 10GB-T ports network module
C3KX-SM-10G
Service Module with two 10GbE SFP+ ports network module for Netflow and MACsec encryption
Hope this helps!
hobbe
Level 7
Level 7
Lets go back to basics
Gig is Gig and it does no difference if you use copper or fiber.(in terms of transfering the data)
If you want to use Fiber, then you will get out of electrical disturbances and grounding problems and such, but it will still only deliver 1 Gig wich is the same as 1 Gig over copper. (same thing as the old question, Wich weights more 1 Kg of feathers or 1 Kg of lead... answer = both weights 1Kg)
so ok you want to use fiber, then you need to buy the network module uplink, I Personally would go for the 3KX-NM-10G.
why ? well since you are able to get 4 normal gig ports OR 2 10 gig ports. the 10 gig ports are maybe not interesting today, but it will most likely be tomorow. and then you are already set for that.
To that module you need to buy a SFP (to plug in to the module and the module plugs into the switch).
That SFP needs to be the same type that the network card supports.
(the network card most likely supports either singelmode or multimode.)
PCI express = the connection to the bus inside the server ie the slot you put the network card in, inside the server.
what does the network card support on the otherside is the magic question.
if the network card supports Singelmode then the SFP needs to be one that can handle single mode.
if the network card supports Multimode then the SFP needs to be one that can handle multimode.
Actually cisco has one SFP that supports both singel AND multimode.
The signal transfer distance is only one of many factors that inflicts on the pricing. so you can not buy a sfp with how much it costs in mind, only what it can support. there are several different types that can support the same distance. ie wavelength (colour of the "laser") and other things.
Buy the correct cabeling with the correct connectors for the fiberoptics.
ok so now you have checked what the network card supports in terms of fiber optics, bought the correct cabeling for connected devices and the cabeling to the switch via the choosen module and correct SFP.
Thats what you need in order to connect your device to the 3750x
now for the bonus question.
Are the 3750x connected in a stack and is it powerstacked ?
if not then I would seriously consider it.
that is one major advantage of the 3750x.
Good link for SFP information
http://www.cisco.com/en/US/products/hw/modules/ps4999/products_tech_note09186a00807a30d6.shtml#support3
good luck
