12-28-2007 09:39 AM
I have loaded CTM 8.0 for the first time to manage my SONET 15454 network. I am having issues "greening" up the view for the NOC. When I use alarm browser i see multiple probable causes "Stratum 1 Primary Reference Source Traceable" with affected objects "SYNC-NE and BITS (1)(2)". From my research these are just warnings and not service affecting. Currently we are running CTC 7.0 and the alarms are just masked. Can I mask these warnings to "green"up the network. Thanks.
01-03-2008 02:31 AM
yes, it's possible. You have to create an alarm profile and set the specific alarms to "Not Report" instead of "Not Alarmed". Your example, Primary Reference Source Traceable is listed as NE-SREF::SSM-PRC. I recommend that you create a new profile on one node. Modify the alarms and test it. Then you can copy that profile on all nodes. You can do it with CTM or CTC.
I did this on all nodes and my nodes are all green, also in CTM;-)
Please rate all posts.
Rene
01-03-2008 08:49 AM
I created the profile and changed the NE-SREF::SSM-PRC to "not report". I applied it to the card ports in question. Still getting the warning and blue nodes and links. I tried a couple of nodes in the network but same issue. Any other ideas.
01-04-2008 03:03 AM
yes, it's very tricky to disable the right alarm codes. Watch the alarm browser when you apply the profile. The warnings should be cleared. How many warnings do you have per node? I remember that I had about 5-6 blue warnings.
I'm sure you should have also the SWTOPRI (switch to primary source). Check also the object, maybe it's NE-SREF or BITS. Disable both. Also, there is a warning about audit and error log full (AUD-LOG-LOSS). These funny error codes are described in Troubleshooting Guide.
Good luck,
cheers
Rene
01-03-2008 08:06 AM
Yes, you can create profile as explained in the previous reply. Note that it is highly recommended that you have your timing that the 15454 have a good timing source. Also by making the Timing warning not reported you might missed an actual timing problem.
