CTM issue with ONS15454 SDH
rvillagran
Hi guys,
I do install a CTM 8.0, and i try to add NE ONS, but it can not recognize it, the error was "AUD-2500: Transport Manager was unable to initialize NE : 172.29.1.108 because 05.02-005C-26.23 is not supported" as far i know and read in Cisco, the workaround for this caso should be change the name of a version closer that one the CTM does not have, by the exact name of the version. I already did it, and the CTM recognize the ONS. but how can i make sure that it will work fine??
The Second question is: in the CTC network view, the node shows in GREEN, meanwhile in CTM are CYAN, that is because there are some warnings in the node, i already did the ACK to the alarms, but it remains cyan. how can i clear the alarms (the clear button does not work) or make the nodes to be shown in green??
thanks in advance
Rodrigo
chrisnowland1
Rodrigo-
I am unsure of your fist question. But I am in the same predicament as you for the second. Nodes will not green up for several warning/informational alarms that we could previously mask in CTC.
Chris
tortifoerster
what is it for an alarm?
tortifoerster
1. question: try it out, if its working fine.
2. question: if you have the problem, a alarm is raised again after some hour, although you acknowledged it before, try this:
uncheck the option of synchronisation between ctm and ctc every x hours in the ctm-database options.
